uniform force in long period of time
    • Mehran
      Hi everyone, i want to apply a fix force in 4 hours to one beam,i dont know how to work with  transient structure.would you help me?
    • peteroznewman
      Hi Mehran,
      Since you mention 4 hours, this implies that inertial forces are insignficant so you can run this model in a Static Structural system. You only need to use Transient Structural if the accelerations get high enough where the inertia forces on the mass become significant.
      You need to create a material with a viscoelastic or viscoplastic behavior to build a model that simulates the creep that occurs when a constant force is applied for a period of time.
      Do you have experimental creep data from a material sample?  That is most important.
    • Mehran
      love you man!  tnx
    • Mehran
      hi peter, im working with a pressure vessel that works in specific working cycle:
      1) 4 hours takes that its pressure become 0 to 103 Mpa
      2) 4 hours holds 103 Mpa
      3) 5 hours takes that its pressure beacome 103 Mpa to 0
      i dont know how simulate this in static stractural or other parts
      can u help me?
      plz explain in simple mode im new with ansys.tnx
    • peteroznewman
      Answered in this discussion.
    • peteroznewman
      For anyone interested in Creep, here is a relevant discussion.
Viewing 5 reply threads
