TAGGED: apdl, laser, moving-heat-source, transient-thermal
November 9, 2020 at 12:23 pm
Jan Keuntje
SubscriberHello,ni am getting started with ansys right now. My goal is to simulate a laser cutting process. I read several threads regarding this topic. Basically there are two options to handle this, eihter using the Moving Heat Source extension or APDL commands. In both cases a gaussian heat source is given. However i am interested in modelling a uniform heat source. Is there a way to get a a uniform circular intensity distribution adapting the extension or using APDL?nAnother question i have is about a possibility of creating a pulsed heat source. I am thinking about adding a factor which is either one or zero depending on time and to multiply it with the power intensity. What might be a good practice to achive thie?nThanks in advance for any information or resources.n -
December 4, 2020 at 8:18 am
Ashish Khemka
Forum ModeratornnPlease see if the following link looks relevant:nnnRegards,nAshish Khemkan
- The topic ‘Uniform Moving Heat’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1680
1470
