TAGGED: ansys-mechanical, apdl, apply-load, function, pressure-load
November 4, 2023 at 4:58 pm
Mare Levin
SubscriberDoes anyone know how to apply a load p=-10*sin(x)*sin(y) to a Plate (Shell) in Static Structural Workbench Ansys? if not could you please provide me with the APDL command that i can insert in command section in Static Structural Workbench.
i would very grateful.
November 8, 2023 at 8:51 am
November 8, 2023 at 9:12 am
Erik Kostson
Ansys EmployeeHi
You can also write a file (location: x y z and pressure(x,y) values), then import that text file into external data and finally use the imported load to map and assign this load onto the structure:
https://forum.ansys.com/forums/topic/imported-pressure-from-external-data-system/
All the best
Erik
- A solver pivot warning or error has been detected
8762
4658
3151
1678
1456
