UNIT PROBLEM MIXED ANSWER TUTORIAL
    • lancer
      Hello, I'm wanted to do the post-processing for sofc.  The post-processing I use is as following:
      The current strength of the electrolyte surface can be calculated with these settings
      Report Type = Integral
      Field Variable = User Defined Memory ... => Interface Current Density
      Surfaces = electrolyte surface
      However, I don't know if its A or A/cm2. When I generate the result,
      [(A/m^2)(m^2)].
      But, all other tutorial that I exactly give different answer as A and A/cm2.
      Which is one is true? Because this will signifacantly determine my power output
    • Murari Iyengar
      Hi, the Current Density units are A/cm2.
