Units in the result file
    • helen.durand
      I am unable to import the temperature load from transient thermal to transient structural in a coupled simulation, and I receive the following error.
    • ciema
      Try to change option from Automatic (default) to Manual, in Analysis Settings (somewhere in bottom, there is an option connected with units) . Ansys will accept units in Mechanical in your command objects and probably results. I am not sure if this will help but you can tryn
