November 10, 2023 at 2:01 pm
Fritz Herschteinmueller
SubscriberHello everyone,
I am trying to create a mesh and export it via Ansys LS-Dyna Workbench in LS-Prepost by using the context tab and the option "Write Input Files..". However, each time that I am exporting the file, my geometry and the mesh are always in mm. Is it possible to scale it for example to meters? If yes, how?
Thanks a lot in advance for your answers.
November 10, 2023 at 2:52 pm
November 10, 2023 at 3:13 pm
SubscriberThank you very much!
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3151
1680
1470
