Discovery Import
Discovery Import
Universal Joint in Discovery
    • kawabata
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      Hello, The simulation of a universal joint is supported in Discovery? As conditions; an end of joint is fixed support , another one is added moment and all contacts are sliding. In this case, the solve failed. When I changed all contacts from sliding to fixed joints, the solve did not failed. And all bonded contacts looked fine. All contacts are sliding is wrong condition? Do I need other conditions? Would you advise me? Thanks, Ichiro
    • Charudatta Bandgar
      Hello Ichiro , Can you try with hinge joints in place of sliding contact? Does that work for you?
      I did it with hinged joints at all locations (Please refer to the attached file). Regards.
      • kawabata
        Hi Charudatta Bandgar ,
        I am sorry for delay.
        I understood.
         Thanks a lot,
            Ichiro
