Unknown Error during Modal Analysis
    • Brax26
      I am trying to perform a simple modal analysis on one simple geometry component after completing a static structural analysis which worked fine. Once I perform modal analysis I get an unknown error and am prompted to check the solver output. In the solver output file I dont see any indication of errors?
      Could someone please point me in the right direction?
    • Brax26
      FYI solver info placed in a note file due to limited word count allowed.
    • bhagwantP
      In solver output file it will details of error. If you coudn;t locate anything over there, derails of error can also viewed in error file created in solver files directory. This will give you idea where simulation is being getting terminated.
    • bhagwantP
      You can locate solver files directory if you right click on solution tab.
      (Missed to add above point)
      Thanks
Viewing 3 reply threads
