December 29, 2022 at 7:43 pm
Sfran
SubscriberI am using Ansys 2022 R2 student version. I'm doing static analyses on simple shapes ie. cylindrical, rectangular, etc. . When I run the solution, I keep getting the error "An unknown error occurred during solution. Check the Solver Output on the Solution Information object for possible causes." I don't get any warning/error about too many nodes/elements and my nodes/elements are around 10k give or take, much less than th 32k allowed for the student version. I have been able to get a solution sometimes if I increase the mesh size significantly for ex. to 0.75" for a cylinder that is only 1 inch long but if I reduced mesh size to say 0.5" I get the error. Can anyone help?
December 30, 2022 at 12:27 pm
Aniket
Ansys EmployeeCan you check your solver output file? What error/s does it show?
-Aniket
December 30, 2022 at 4:53 pm
Sfran
SubscriberI tried but am unable to locate the file on my C:\drive. The file path that Ansys provided in the "Solution Information" is below but it doesn't seem like it created the file or the file folders. Not sure if I am missing something in searching for the file but I went to "C:\Users\lastname" but there is not an "AppData" folder there. I also did a "C:\drive" search for the file name "file.err" but nothing was found.
Note: I substituted "lastname" for privacy reasons in the path below.
Below is from "Solution Information"
*** NOTE *** CP = 3.062 TIME= 11:25:38
The model data was checked and warning messages were found.C:\Users\lastname\AppData\Local\Temp\WB_lastname_12240_2\_ProjectScratch\
\ScrA05E\file.err ) for these warning messages. -
January 1, 2023 at 11:11 pm
Bill Bulat
Ansys EmployeeHello,
Please save your project. For example, I saved a project to directory named "2023R1_test". I saved the project using the project name "xsient_piezo_acoustic". This will create directories such as those shown below. Several levels below the directory named "xsient_piezo_acoustic_files" ("your_project_name_files"), you will see a directory named "MECH". In the MECH directory there are two text files that may contain the reason(s) the run was not sucessful (solve.out & file .err). Please inspect these using any text editor (e.g., notepad).
Happy New Year,
Bill
January 2, 2023 at 7:00 pm
Sfran
SubscriberI saved the project per above. Below is what the "file.err" file had and last part of the "solve.out" file. I didn't see any errors in either file so not sure where to go from here.
Contents of "file.err".
/COM,ANSYS RELEASE 2022 R2 BUILD 22.2 UP20220516 13:23:33
*** WARNING *** CP = 3.094 TIME= 13:23:37
Element shape checking is currently inactive. Issue SHPP,ON or
SHPP,WARN to reactivate, if desired.*** WARNING *** CP = 3.453 TIME= 13:23:37
Material number 2 (used by element 2583) should normally have at least
one MP or one TB type command associated with it. Output of energy by
material may not be available.Partial contents of "solve.out"
***** MAPDL SOLVE COMMAND ******** WARNING *** CP = 3.094 TIME= 13:23:37
SHPP,WARN to reactivate, if desired.*** NOTE *** CP = 3.297 TIME= 13:23:37
Please review output or errors file (
C:\Users\lastname\AppData\Local\Temp\WB_lastname_9764_2\_ProjectScratch\S
Scr7CDD\file.err ) for these warning messages.*** SELECTION OF ELEMENT TECHNOLOGIES FOR APPLICABLE ELEMENTS ***
--- GIVE SUGGESTIONS AND RESET THE KEY OPTIONS ---ELEMENT TYPE 1 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
HYPERELASTIC MATERIALS. NO SUGGESTION IS AVAILABLE AND NO RESETTING IS NEEDED.*** MAPDL - ENGINEERING ANALYSIS SYSTEM RELEASE 2022 R2 22.2 ***
Ansys Mechanical Enterprise Academic Student
00000000 VERSION=WINDOWS x64 13:23:37 JAN 02, 2023 CP= 3.359wbnew--Static Structural (A5)
S O L U T I O N O P T I O N S
PROBLEM DIMENSIONALITY. . . . . . . . . . . . .3-D
DEGREES OF FREEDOM. . . . . . UX UY UZ
ANALYSIS TYPE . . . . . . . . . . . . . . . . .STATIC (STEADY-STATE)
OFFSET TEMPERATURE FROM ABSOLUTE ZERO . . . . . 459.67
EQUATION SOLVER OPTION. . . . . . . . . . . . .SPARSE
GLOBALLY ASSEMBLED MATRIX . . . . . . . . . . .SYMMETRIC*** WARNING *** CP = 3.453 TIME= 13:23:37
material may not be available.*** NOTE *** CP = 3.516 TIME= 13:23:37
The step data was checked and warning messages were found.
Scr7CDD\file.err ) for these warning messages.*** NOTE *** CP = 3.562 TIME= 13:23:37
The conditions for direct assembly have been met. No .emat or .erot
files will be produced.L O A D S T E P O P T I O N S
LOAD STEP NUMBER. . . . . . . . . . . . . . . . 1
TIME AT END OF THE LOAD STEP. . . . . . . . . . 1.0000
NUMBER OF SUBSTEPS. . . . . . . . . . . . . . . 1
STEP CHANGE BOUNDARY CONDITIONS . . . . . . . . NO
PRINT OUTPUT CONTROLS . . . . . . . . . . . . .NO PRINTOUT
DATABASE OUTPUT CONTROLS
ITEM FREQUENCY COMPONENT
ALL NONE
NSOL ALL
RSOL ALL
EANG ALL
ETMP ALL
VENG ALL
STRS ALL
EPEL ALL
EPPL ALL
CONT ALL
SOLUTION MONITORING INFO IS WRITTEN TO FILE= file.mntr*********** PRECISE MASS SUMMARY ***********
TOTAL RIGID BODY MASS MATRIX ABOUT ORIGIN
Translational mass | Coupled translational/rotational mass
0.55957E-04 0.0000 0.0000 | 0.0000 0.61305E-09 -0.27292E-04
0.0000 0.55957E-04 0.0000 | -0.61305E-09 0.0000 -0.46874E-08
0.0000 0.0000 0.55957E-04 | 0.27292E-04 0.46874E-08 0.0000
| Rotational mass (inertia)
| 0.16809E-04 0.26878E-08 -0.60965E-10
| 0.26878E-08 0.15910E-05 -0.61394E-09
| -0.60965E-10 -0.61394E-09 0.16810E-04TOTAL MASS = 0.55957E-04
The mass principal axes coincide with the global Cartesian axesCENTER OF MASS (X,Y,Z)= -0.83769E-04 0.48773 0.10956E-04
TOTAL INERTIA ABOUT CENTER OF MASS
0.34980E-05 0.40158E-09 -0.61016E-10
0.40158E-09 0.15910E-05 -0.31494E-09
-0.61016E-10 -0.31494E-09 0.34985E-05
The inertia principal axes coincide with the global Cartesian axes
*** MASS SUMMARY BY ELEMENT TYPE ***TYPE MASS
1 0.559568E-04Range of element maximum matrix coefficients in global coordinates
Maximum = 15489976.9 at element 1201.
Minimum = 506190.43 at element 674.*** ELEMENT MATRIX FORMULATION TIMES
TYPE NUMBER ENAME TOTAL CP AVE CP1 1654 SOLID187 1.875 0.001134
2 52 SURF154 0.000 0.000000
Time at end of element matrix formulation CP = 4.828125.SPARSE MATRIX DIRECT SOLVER.
Number of equations = 9030, Maximum wavefront = 288
Memory allocated for solver = 26.376 MB
Memory required for in-core solution = 25.390 MB
Memory required for out-of-core solution = 12.757 MB*** NOTE *** CP = 5.719 TIME= 13:23:39
The Sparse Matrix Solver is currently running in the in-core memory
mode. This memory mode uses the most amount of memory in order to
avoid using the hard drive as much as possible, which most often
results in the fastest solution time. This mode is recommended if
enough physical memory is present to accommodate all of the solver
data. -
January 3, 2023 at 10:06 am
Aniket
Ansys Employee -
January 4, 2023 at 12:07 am
Sfran
SubscriberYes, correct.
January 16, 2023 at 5:58 pm
Sfran
SubscriberI tried another part to analyze and got an error in the "file.err" file. The full contents of the "file.err" file are shown below.
/COM,ANSYS RELEASE 2022 R2 BUILD 22.2 UP20220516 12:53:11
*** WARNING *** CP = 3.531 TIME= 12:53:17
SHPP,WARN to reactivate, if desired.*** WARNING *** CP = 3.828 TIME= 12:53:18
Material number 2 (used by element 2023) should normally have at least
material may not be available.*** ERROR *** CP = 6.859 TIME= 12:53:25
An unexpected error ( SIG$ILL ) has occurred... ANSYS internal data
has been corrupted. ANSYS is unable to recover and will terminate.
Previously saved files are unaffected. Please send the data leading
to this operation to your technical support provider, as this will
allow ANSYS, Inc to improve the program. -
January 16, 2023 at 7:15 pm
Aniket
Ansys EmployeeDo you get this error for simple geometries as well? Or do you get it for specific ones?
-Aniket
January 18, 2023 at 2:34 am
Sfran
SubscriberYes, I am now getting this error in the "file.err" file for both simple and more complicated geometry. I originally did not on a simple part geometry I did a static analysis on. I did find another thread post that referenced "Mechanical APDL crashes with “SIG$ILL” during solving" and the thread said to add "-blas intel" under solve process settings>Advanced then in the Additional Command Line Arguments field add "-blas intel" without the quotes. I did this and both the simple and more complicated models static analyses work and solved.
January 18, 2023 at 3:02 am
Aniket
Ansys Employeeok are you using shared memory parallel or distributed memory parallel? Check the physical cores available (N) on your machine, (Not Logical Processors) and run a simple model first using shared memory parallel (i.e. uncheck the Distributed checkmark) using N - 2 or N - 4 cores.
-Aniket
January 19, 2023 at 1:45 am
Sfran
SubscriberI unchecked "distribute solution (if possible)" in solver process settings>advanced and removed "-blas intel" and ran a simple square tube beam with a load and one end fixed and it would not solve. The "file.err" file only had 2 warnings shown below. I then checked "distribute solution (if possible)" and added back the "-blas intel" in the Additional Command Line Arguments field and re-ran model which then solved.
Entire contents of "file.err" file are below.
OM,ANSYS RELEASE 2022 R2 BUILD 22.2 UP20220516 20:38:51
*** WARNING *** CP = 1.484 TIME= 20:38:56
SHPP,WARN to reactivate, if desired.*** WARNING *** CP = 1.625 TIME= 20:38:56
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2630
2104
1327
1110
461
