December 18, 2019 at 2:44 am
December 18, 2019 at 1:49 pm
Ansys EmployeeOdd. Has anything changed, or will anything change at that solution time/timestep? What happens if you click iterate again?
December 18, 2019 at 1:58 pm
AndyHor
SubscriberI had tried for many days in the uni lab. Because the lab closed at 5pm everyday, so I let it run overnight, but when i get back the next morning, it prompted this message. I didnot do any change on the computer. When I click ok on the error box, It say calculation completed and stop at the time step.
December 19, 2019 at 11:51 am
Ansys EmployeeWeird. Try dropping the time step as you're aiming for convergence in 10-15 iterations. I wonder if it's a convergence issue somewhere. Also write a transcript (under File) so you can check when it fails: it could be IT related.
December 19, 2019 at 2:28 pm
AndyHor
SubscriberYes, could you please teach me on how to write a transcript to check ?
December 19, 2019 at 3:09 pm
Ansys EmployeeLook in the File menu. There will be a "start transcript" option, may be down a menu level depending on whether you're also using Workbench.
December 20, 2019 at 6:39 am
AndyHor
SubscriberYes I am using Workbench R1. I found a funny trick, before I run overnight calculation, I have to save, close the Workbench, and restart again then run the calculation, It is okay then till now, 2 days. I will see whether it will prompt any error a few days later.
July 2, 2022 at 8:31 am
1456766892
Subscriberoh god, I have the same problem.My calculation time step number is very large, do not know how to solve this matter.
May 9, 2023 at 5:24 am
- Changing of font size
- System Coupling
- 3D ROM in workbench
- ANSYS Workbench Mechanical Solver problem after saving
- ansys with matlab
- Error message “Solver pivot warning” due to element birth and death
- HARDWARE COMPATIBILITY
- System Coupling
- ANSYS Direct Optimization
- When I open the Electronic Desktop, Twin Builder auto opens
5174
3275
2453
