Unnatural values calculated by UDF
    • James
      Hello!
      I am trying to model fixed bed adsorption using Linear driving force model given by dq/dt = kf(q* - q) where kf is a constant q* = (KL*qm*C)/(1 + KL*C), where KL and qm are constants and C is the concentration. I defined C as a user defined scalar instead of using mass fraction for convenience with numbers (Does that make any difference?). The dq/dt equation is then applied in the source term as -(1-porosity)*rho*dq/dt.
      I put messages in my UDF to show me the values of the UDS and other variables calculated and they are absolutely ridiculous. An example is:
      The value of q_i is now -38065484171715682240850117399674880.000000
      q_i is the value of q at the previous time step.
      Anyway, can someone look at my code and see where I am going wrong, please?
      #include
      #include
      DEFINE_INIT(Initial,domain)
          Thread *t;
          cell_t c;
          thread_loop_c(t, domain)
              begin_c_loop(c, t)
                  // Initially the contaminant concentration in solid phase is 0
                  C_UDMI(c, t, 0) = 0.0; // q_i at the ith time step
                  C_UDMI(c, t, 1) = 0.0; // q_i+1 at the i+1th time step
              end_c_loop(c, t)
      DEFINE_ADJUST(define_q_ads, domain)  /*Adjust is the first step in the solution loop*/
          Thread *t;
          cell_t c;
          real dt;
          real rp = 1.1/1000;
          real De = 25;
          real qm = 154;
          real KL = 0.63;
          real kf = 15*De/(rp*rp);
          real qe;
              begin_c_loop(c, t)
                  dt = RP_Get_Real("physical-time-step");
                  qe = (KL*qm*C_UDSI(c,t,0))/(1+KL*C_UDSI(c,t,0)); // C_UDSI contains the concentration in the liquid phase
                  C_UDMI(c, t, 1) = C_UDMI(c, t, 0) + kf*dt*((qe - C_UDMI(c, t, 0)));
                  // q_i+1 = q_i + kf*dt*(qe - q_i)
              end_c_loop(c, t)
      DEFINE_SOURCE(m_src, c, t, dS, eqn) /*Source term calculation happens after the adjust function*/
          real source;
          real eta = 0.77;
          real rho = 743;
          int ThreadID = THREAD_ID(t);
          source = -(1-eta)*rho*C_UDMI(c,t,1);
          Message("====================================================================\n");
          Message("The value of source in the cell thread %i is %f\n", ThreadID, source);
          dS[eqn] = 0.0;
          return source;
      DEFINE_EXECUTE_AT_END(execute_at_end)  /*Executes at the end of the iteration. Updates q_i for the next time step*/
          Domain* domain = Get_Domain(1);
          Thread* t;
          cell_t c;
              begin_c_loop(c, t)
                   C_UDMI(c, t, 0)=C_UDMI(c, t, 1);
                   Message("The value of q_i is now %f\n",C_UDMI(c,t,0));
              end_c_loop(c, t)
    • Atharva Nagarkar
      Hello!
      As part of the Ansys policy, employees cannot debug UDFs on the forum. However, I would suggest you to have a look at the following things.
      For the macro C_UDSI, if you try to use the macro before you have specified the user-defined scalars in your Ansys Fluent model then an error will result.
      3.2. Data Access Macros (ansys.com) -> Check section 3.2.11.3
      Please also have a look at the definition of the macro C_UDMI and how the arguments are defined at the link below.
      3.2. Data Access Macros (ansys.com) -> Check section 3.2.12.4
      Additionally, this is the link from the Ansys manual for defining the source term. Make sure that you have correctly defined the dS[] array with respect to the dependent variable.
      2.3. Model-Specific DEFINE Macros (ansys.com) -> Check section 2.3.43
      Lastly, these are the time dependent macros which you can use to access variables for previous timesteps.
      3.5. Time-Dependent Macros (ansys.com)
      If you are not able to access the link, please refer to this forum discussion: Using Help with links (ansys.com)
      Thanks!
      • James
        I will take care next time, and thank you!
