Unrealistic deformation in a linear static analysis
    • Oimpa
      I have a model that includes two parts solid and shell.
      I've joined these two parts with merge nodes.
      I want to do a linear static analysis on them.
      After analysis, deformations are very small(0.3e-7).But in some places in the model, these two parts go inside or go apart.
      While this does not happen, if I do a non-linear analysis on the same model with the same characteristics.
      Is this a real deformation?
    • peteroznewman
      No, it's not a real deformation, it is just the deformation display scale that is set to a number much larger than 1.  When you run a non-linear analysis, the deformation display scale is set to 1.0.  I am a Mechanical Workbench user, so I don't know the APDL menu or command to change the display scale.
    • Oimpa
      Thanks
    • jj77
      Yes, when nlgeom, on is active so large displacement is on then deformation scale is 1. /dscale, all, 1 command can set that.
      We are all using apdl, just different pre and post processors (ansys classic gui or wb gui).
Viewing 3 reply threads
