March 18, 2021 at 1:34 pm
gwqsz
SubscriberHellonI'm going to simulate the diffusion of particles in the human body as it breathes.The flow field is transient. Since human respiration is in continuous circulation, DPM injection should also be in continuous circulation.I'm a beginner and don't quite understand how to set it up.I checked the help documentation and couldn't find a solution.nThanksn -
March 18, 2021 at 2:30 pm
Ansys EmployeeDo you want particles added all the time? n -
March 18, 2021 at 2:51 pm
DrAmine
Ansys EmployeeYou can use a transient profile for the injection and make it cyclic. Transient profiles are documented in the Fluent Guide. The total mass flow rate of the particles will be then time dependent and cyclic (over certain period)n -
March 19, 2021 at 6:36 am
gwqsz
SubscriberDo you want particles added all the time?https://forum.ansys.com/discussion/comment/111423#Comment_111423
There is no need to inject particles into the body when the gas is inhaled, it is a cyclic process.n -
March 19, 2021 at 3:03 pm
Ansys EmployeeIt is, how do you want to add particles to the system? Ie single injection at the start to see how they're in/exhaled or regular breathing in a dusty environment? n -
March 22, 2021 at 10:38 am
DrAmine
Ansys EmployeeTransient injection profile should make the job.n -
March 23, 2021 at 12:49 pm
gwqsz
SubscriberYou can use a transient profile for the injection and make it cyclic. Transient profiles are documented in the Fluent Guide. The total mass flow rate of the particles will be then time dependent and cyclic (over certain period)https://forum.ansys.com/discussion/comment/111442#Comment_111442
Thank you very much for your answers. I have solved this problem.n -
March 23, 2021 at 1:06 pm
DrAmine
Ansys EmployeeSuper!n
2588
2080
1315
1108
459
