unsteady heat transfer rate calaculation
    • Alexandre11
      Hai..
      Problem Specification
      A fluid flows through a solid region where a transient heat source is present. The cp value of fluid depends on temperature.
      How to plot the amount of heat absorbed by the fluid over time in cfd post.
      Regards
    • DrAmine
      That would be theat released by
      The solid region in contact with fluid. Say heatflux at contact interface on the fluid side.
    • Alexandre11
      Thanks for the reply.
      Sorry. I could not understand your answer. Can you explain it a bit more?
      Thanks
    • DrAmine
      In Fluent or CFX you have your Fluid passing though a solid region. Imagine now both are meshed and part of your model. CFX or Fluent will build up a sort of an interface or similar between both. At that interface you can look for the heat flux transferred between the solid body and fluid region. Look after the variable Heat Flux in Post which you can integrate along the Wall/Interface/Contact.
      For more information you need to post some more details here so that we can be more specific here.
    • Keyur Kanade
      A quick check in Fluent would be Postprocessing - Reports - Fluxes - Heat transfer rate
Viewing 4 reply threads
