Unstructured ICEM Prism ERROR
    • CMHR
      I tried to mesh a 3D wing on ICEM using an unstructured approach. However, every time I check for "create prism layers" under the volume mesh tab, I receive an error, as stated below. This error appears right after the mesh is generated but has no inflation layer yet.
      running on Windows (64 bit version)
      (c) Copyright 1991 - 2021 ANSYS Inc.
      reading surface model...
      reading mesh file...
      failed to allocated 12252 megabytes
      to store 72995899 tets of 176 bytes each
      could not allocated -37623664 bytes for 72995899 tetras
      Application is finished.
      Error: prism terminated prematurely>>
      Can you please explain why this occurs? I understand that it's a memory issue, but I can not reduce the cell sizes on my wing, or else the mesh does not follow my geometry.
      Thank you very much.
    • Keyur Kanade
      Yes, it looks like memory issue. Can you please create coarse mesh or reduce problem size by using some symmetry etc.
      Regards Keyur
    • CMHR
      Hi, Thank you for your reply.
      It worked out in the end. I just refined on some areas and made everywhere else coarse. Just a follow-up, what do you mean by, "reduce problem size by using some symmetry"?
      Thank you.
    • Keyur Kanade
      If your geometry /flow has symmetry then you can only use that portion instead of full geometry.
Viewing 3 reply threads
