3D Design
3D Design
unusual deformation on model
    • Sushil Sharma
      I am doing a static analysis of a wind turbine blade model, where I applied forces at a remote point (shown in the first figure). While observing the output, there is some unusual deformation in some locations of the model (shown in the second figure). The deformation occurs at the cross-sectional plane where I apply my remote load. I use a flexible MPC equation because of sectional deformation with load application. How can I find what is the reason behind such deformation? And how can I solve this issue? The deformation can be seen in the second figure near the hub.
      Thank you
    • Ashish Khemka
      Hi Sushil,
      Can you please check the value of deformation in the deformation plot? Also, please see if you view the results in true scale.
      Ashish Khemka
    • Sushil Sharma
      Hi Ashish,
      Overall, the model has normal deformation. My question is about the dent in the model after the analysis (seen in the attached figure). Why is that happening? It is unusual for my loading situation. Can the deformation plot be viewed for the selected parts only?
      thank you
    • Ashish Khemka
      Try plotting the deformation for parts of interest. I cannot comment why a dent is there without looking at the model. But Ansys employees cannot download the model.
      Ashish Khemka
Viewing 3 reply threads
