Preprocessing
Preprocessing
Unwanted combination of two surface from geometry to mesh
    • jacobier
      HinI have drawn two 2D rectangular surfaces connected to each other in the DesignModeler. However when I connected them to mesh, they were merged as one body. I need to assign different properties for them. How can i separate them?n
      Named Selections tend to prevent this from happening, but it's rare to lose the surface when moving to mesh. Please post some images. n
    • jacobier
      I found out the root of the problem. It was merge as one body in the DesignModeler. How can i separate them or create a new body/part?n
      Look at how (and what) the surface creation options interact. You probably created both bodies as unfrozen, create as frozen and see what happens. n
    • Keyur Kanade
      Please select Add Frozen while creating surface. nnPlease see help manual for more details about these commands. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn
Viewing 4 reply threads
