March 18, 2021 at 7:13 pm
Raj007
SubscriberMarch 19, 2021 at 6:06 amKeyur Kanade
Ansys EmployeeThere must be some other body which is touching at that place. Due to this when you go to meshing it is creating that imprint. nIf there is not other body, you can use virtual topology. nPlease go through help manual for more details nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynMarch 20, 2021 at 2:20 pmRaj007
SubscriberYeah, there was a body touching, but I sliced the geometry at that surface. I cannot see the imprint in the geometry tool (which is in blue color). So, I want to know how can it be seen in the mesh tool which is after the geometry tool window.nnMarch 22, 2021 at 8:26 amKeyur Kanade
Ansys EmployeeIt will be seen after sharetopology. nPlease check following videosnnDM ShareMarch 22, 2021 at 7:13 pmRaj007
SubscriberOkay. But, could you help me or suggest to me how to get a structured mesh in Ansys for that type of geometry.nThank younRajnMarch 22, 2021 at 7:33 pmRaj007
SubscriberAs I am trying to mesh with the imprint. I am facing this error Patch-conforming tetrahedron mesh failed because of an edge intersection in the boundary mesh.n. Please let me know what can I do with that?.March 23, 2021 at 5:04 amKeyur Kanade
Ansys EmployeeIf you want structured mesh you will need to split the geometry. please check following videos. nnViewing 6 reply threads- You must be logged in to reply to this topic.
2534
2066
1285
1104
459
