February 16, 2021 at 8:13 am
Stefan_Panajotovic
SubscriberHello,
I am trying to simulate a flow of water through an externally heated pipe with a porous core. Since I am interested in the temperature distribution in both solid and fluid domains, I am analyzing both of them in Fluent. Here is the model as shown in Mechanical block:
February 16, 2021 at 8:43 amDrAmine
Ansys EmployeeCan you show the cell zones conditions?nFebruary 16, 2021 at 8:45 amFebruary 16, 2021 at 12:13 pmDrAmine
Ansys EmployeeCan you just change the names of the boundaries to something like interior_1 and interior_2 before reading the mesh into Fluent?nFebruary 16, 2021 at 2:28 pmRob
Ansys EmployeeIt's because you used a special label in the model. Inlet, outlet, outflow, symmetry and some others force the solver to set a certain boundary type. It is fixable in Fluent, but not without some TUI commands and knowledge of the solver. As suggests alter the named selection in Meshing and it'll come through OK. nFebruary 16, 2021 at 2:30 pmStefan_Panajotovic
SubscriberIndeed, I changed the names to Interior 1 and 2 and the problem got solved. Thank you a lot! nViewing 5 reply threads- You must be logged in to reply to this topic.
5268
3299
2469
