LS Dyna
LS Dyna
Unwanted Penetration in Simulation
    • hansenli
    • Ram Gopisetti
      have you tried with *CONTACT_ERODING_NODES_TO_SURFACEand what formulation is the SPH?. i dont think this is grinding off rather collapse of the bonds, what is your material propertiesm do include some failure conditions to erode the particels.
      cheers, ram
    • hansenli
      The mesh is set to be a rigid body, and the SPH part is silicon carbide. The mesh can displace in y direction. I have tried to turn on penetration check in contact node to surface, but the penetration still happens.
    • Ram Gopisetti
      Hi @hansenli, what is your material model used in here?, any hydrodynamic terms, failure terms,
      Cheers, Ram
    • hansenli
      The material model for SPH part is Johnson-Holmquist-Ceramics. For the mesh part, the model is MAT_RIGID. I have also attached our contact setup.
      Thanks, Hansen
Viewing 4 reply threads
