January 15, 2023 at 10:50 pm
ehsan.sadeghi
SubscriberI have the following UDF for changing BC for a UDS in every iteration until it reaches a desired condition. Basically what I want to do is check C_UDSI values of UDS0 on inlet faces and if its value is equal to E_peek assign C_UDSI of UDS1 to q. I am using adjust function to get the values of q and store it in UDMI to later use it in F_PROFILE.
I am not sure if the way that I have implmented this UDF is correct, cause when I hook it and run the simulation, Fluent gives error. The UDF gets compiled without any error. I appreciate if you can give me some hints to know where is the problem in my code.
Thanks
DEFINE_ADJUST (UDF_adjust, d)
/*Domain definition variables */
Thread *t;
cell_t c;
face_t f;
/*q_density tracking variables*/
real q_star=0;
real q;
real w = 0.1;
real E_peek = (3E6*1.0) + (9E4/(sqrt(1.0/0.1)));
/* Do nothing if gradient isn't allocated yet. */
if (! Data_Valid_P())
return;
thread_loop_f(t,d)
begin_f_loop(c,t)
if (fabs(F_UDMI(f,t,3)-E_peek) <= 0.001)
q = F_UDSI(c, t, 1);
else
q_star = F_UDSI(c, t, 1)*(F_UDMI(f,t,3)/E_peek);
q = w*q_star+(1.0-w)*F_UDSI(c, t, 1);
end_f_loop(c,t)
January 16, 2023 at 3:52 pm
Ansys EmployeeWhat error are you getting?
January 16, 2023 at 8:44 pm
ehsan.sadeghi
Subscriber===================================================================================
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= RANK 0 PID 1228 RUNNING AT PC-ANSYS-157
= EXIT STATUS: -1 (ffffffff)
January 17, 2023 at 9:43 am
Ansys EmployeeAnything above that?
January 17, 2023 at 10:19 am
ehsan.sadeghi
SubscriberFluent gets closed after appearing this message. I found in the logs the following error:
Cortex received a fatal signal (SEGMENTATION VIOLATION).
January 17, 2023 at 11:33 am
Ansys EmployeeKnocking the solver over takes some doing. If you open the transcript has the solver done an interation (or few) and then failed or failed before doing an iteration?
Note, I'm not going to debug or do much with the UDF. It's beyond what we're able to support on here, and my UDF coding skills aren't all that high.
January 17, 2023 at 11:39 am
ehsan.sadeghi
SubscriberProblem solved! the face values were not saved in UDMI -
January 17, 2023 at 11:48 am
Ansys EmployeeExcellent. I think there's a UDM for faces too, so have a look at the face-cell data macros.
2524
2066
1279
1096
457
