May 24, 2023 at 11:03 pm
xingzh
SubscriberHi everyone,
I have an issue when I tried to run the Workbench on a cluster. My model runs well on my own computer but did not even start to run on the cluster.
In the error.txt, it shows that:
Traceback (most recent call last):
File "/cvmfs/restricted.computecanada.ca/easybuild/software/2020/Core/ansys/2022R1/v221/SEC/SolverExecutionController/runsec.py", line 34, in
main(sys.argv)
File "/cvmfs/restricted.computecanada.ca/easybuild/software/2020/Core/ansys/2022R1/v221/SEC/SolverExecutionController/runsec.py", line 14, in main
return dynamicMain(args)
File "/cvmfs/restricted.computecanada.ca/easybuild/software/2020/Core/ansys/2022R1/v221/SEC/SolverExecutionController/runsec.py", line 31, in dynamicMain
return sec.sec.execute(runScriptFilePath=__file__)
File "/cvmfs/restricted.computecanada.ca/easybuild/software/2020/Core/ansys/2022R1/v221/SEC/SolverExecutionController/sec/sec.py", line 696, in execute
return executeWithDefinedSecInputDictionaries(dirTuple, mergeDictionaries(inputAndModifierPair[0], inputDataDict), mergeDictionaries(inputAndModifierPair[1], modifierDict), pluginNamespacePrefix, setExitCode, inputFileName, runScriptFilePath)[0]
File "/cvmfs/restricted.computecanada.ca/easybuild/software/2020/Core/ansys/2022R1/v221/SEC/SolverExecutionController/sec/sec.py", line 704, in executeWithDefinedSecInputDictionaries
return doExecuteWithDefinedSecInputDictionaries(dirTuple, inputDataDict, modifierDict, pluginNamespacePrefix, setExitCode, inputFileName, runScriptFilePath)
File "/cvmfs/restricted.computecanada.ca/easybuild/software/2020/Core/ansys/2022R1/v221/SEC/SolverExecutionController/sec/sec.py", line 843, in doExecuteWithDefinedSecInputDictionaries
raise NoRunSolverFunctionMatches("No function to run the solver was found")
sec.sec.NoRunSolverFunctionMatches: 'No function to run the solver was found'
Framework error caught :
Fatal error: Update failed for the Solution component in 1strun. Error updating cell Solution in system 1strun.
Does anyone have the same issue and know how to debug it?
Thank you very much,
Xing
3297
2469
