Discovery Import
Discovery Import
Update failed for the solve physics component in study….. + Mesh region does not exist
    • marco.westerkowsky
      since a couple of days I witness same problem over different AIM releases (19.2 & 2019R1). I open an already solved simulation. Don´t change any settings. Just a small value to get a "out of date" and to rerun the solving and I get the errors shown in the pictures. Did a lot of different variations. Always the same. Even when i build up a new simulation. We did a training and did everything in the same way. For the others it worked and  I get those errors. It´s quite urgent so I´d appreciate a quick help. We will probably try a fresh installation tomorrow. But some advice would be helpful. Thanks a lot!
    • Brian Bueno
      Marco
      If other colleagues can run the same files without any errors, then this is likely caused by something in your options or the installation.  I would recommend clearing the user settings from the File menu > Tools > Options > Restore Defaults.
      If that doesn't work, then uninstalling may fix the problem.  Please let me know if this problem continues after reinstalling.
      Hello Brian, thanks for your reply.
      reinstalling fixed the issue.
