Update solution failed..
    • Doom26
      after 11h of processing, the Ansys just showed me this error code:
      -(DP0) Update solution failed                                        (06:59:45)
      -(DP0) Error writing "|gzip-2cf > FFF.1-1.cas-gz"         (06:59:43)
      -(DP0) There is no active application                            (06:59:43)
      I really have no idea how these error occurs. Did anyone else had this errore before?
      Thank you!
      Workbench has failed to write a file. Check folder permissions, but also disc space and whether you can manually update that design point.
