March 8, 2021 at 5:11 am
xuduan
SubscriberI am working on having an excel sheet driving dimensions of a simple wing to produce the lift and drag coefficients. I would like to change values in the excel sheet, save it, then have it automatically update design parameters. However, when I change the value in excel it does not update in workbench. Is there a way to resolve this? n -
March 8, 2021 at 5:21 am
Keyur Kanade
Ansys EmployeePlease check following. nPlease check following. nnArrayRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn -
March 8, 2021 at 5:24 am
xuduan
SubscriberI have seen this video before and I followed it to get my file set up. My issue is that if I change the value in the excel it does not automatically update the workbench value. nFor example, if I change the thickness shown in the video at 5:35 from 0.25 to 0.5, it would not change the actual model. n -
March 8, 2021 at 9:17 am
Keyur Kanade
Ansys EmployeePlease make sure that you have defined it correctly at geometry level. nPlease open SpaceClaim and make sure that changing this parameter actually works. n
Viewing 3 reply threads
Trending discussions
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
Top Contributors
2524
2066
1279
1096
459
Top Rated Tags
