Preprocessing
Preprocessing
updating geometry after meshing
    • Amin1372
      Hi everyone,nThe geometry of my model cannot be updated after meshing and I get this error, can you please help me to fix that? nOne or more objects may have lost some scoping attachments during the geometry update. You can identify these tree objects by filtering the tree using the Scoping option set to Partial.
    • Keyur Kanade
      Do you want to update geometry or mesh?nThis looks like you get this warning in meshing. nIf you modify geometry and go to meshing then meshing tries to identify the meshing controls defined. e.g if you have selected some face and has given some face sizing. nIf geometry modification has altered that face then meshing can not find that face, Then meshing gives this warning. nPlease check all meshing controls and redefine them if required.nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn
