May 24, 2022 at 4:54 pm
Patrik_micek
SubscriberGreetings, I would like to ask whether it is possible to update the model from https://support.lumerical.com/hc/en-us/articles/360042097313-Metalens-Zemax-Interoperability with my own parameters. Specifically I would like to increase the span of the simulation region up to 0.9x0.9 um in the x-y plane, but whenever I do it manually in the structured group, the settings go back to 0.45x0.45 um as before. I was not able to find the script part responsible for this.
Thank you in advance for your answer.
Best wishes, Patrik Micek
May 24, 2022 at 6:58 pm
May 25, 2022 at 5:54 am
Patrik_micek
SubscriberThank you very much! It helped
Best wishes, Patrik
- Error on Lumerical device
3744
2573
1809
1236
594
