August 20, 2018 at 11:14 am
Anuj Kumar Sahoo
SubscriberI want to use PIN diode in my circuit in HFSS. Can I use the S2P file of diode for the same? I found out, resistor and capacitor has to be used for ON and OFF state, respectively. Is it so? Which one is correct and feasible in HFSS?
August 29, 2018 at 5:05 pm
slouie
Ansys EmployeeHi Anuj,
You may place ports in your HFSS model where you'd like to connect the PIN diode. The S2P file can be connected to these ports in Circuit. The procedure for this is described in our Dynamic Link workshop. See Customer Portal link below for access to this workshop:
https://support.ansys.com/AnsysCustomerPortal/en_us/Knowledge%20Resources/Tutorials%20&%20Training%20Materials/Training%20Files/ANSYS+HFSS+for+Antenna+Design+Training+17.0
October 5, 2018 at 12:51 am
robinirazoqui
SubscriberI can't seem to login to costumer portal, is there any way you can make this public?
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1285
1096
459
