Use same fluent meshing and setup settings for 20 different aircraft geometries
    • santiago requena
      I need to test around 20 different aircraft geometries. The models are created in solidworks and only have some variations on the wings, so the mesh settings have to be identical for all of them. is there a way to automate this process to avoid spending two days just doing meshing?
      Thank you very much!
    • Keyur Kanade
      You mentioned you are using Fluent Meshing.
      Yes, you can automate this. If you are using watertight workflow, you can save settings and use them for second iteration.
      You can also use journal files to automate. Please check the forum for journal files.
      Please go through help manual for more details
      Keyur
      Fluids Engineering Courses | Ansys Innovation Courses
