User defined countours
    • saichandra24
      I'm working on a project in natural ventilation. I wanted to create a contour i.e dimensionless mean velocity magnitude (V/Uref) which is shown in the uploaded image. Can any one help me out on creating this contour.
      Staff are not permitted to open attachments.
      If you're in Fluent have a look at Custom Field Functions: that's how I'd do it.
      In CFD Post you'll need to write an expression.
      Both methods are covered in the documentation.
    • saichandra24
      Thanks rwoolhou,
      I'm using ANSYS 18.0 for my work. I'll check the custom field function and also try to write expression.
      Is there a way to show you the contour? I did not get what documentation you are talking about. Can you please specify it.
      Thanks for your response.
    • Keyur Kanade
      Please use latest version 202R1.
      below is the link for documentation.
      Keyur
Viewing 3 reply threads
