User defined function is not working!
    • nellysh2017
      Hello,nI am trying to run user defined function (NLPLWK) in ANSYS 2020 R1. I get this error: Unable to create user defined result. NLPLWK is not a recognized result in:73904 = NLPLWK.nWhat am I doing wrong?n
    • Govindan Nagappan
      nCheck and see if you have 'Nonlinear Data' turned on under Analysis Settings > Output Controls. nAlso make sure, large deflection is on under Analysis Settings -> Solver ControlsnMake sure you have plasticity defined for the materialnMake sure you solve the model with these settings nAnd then check if you are able to plot plastic strain resultn
    • nellysh2017
      Thank you for your reply. I get an error for not converging after making these changes.n
  • The topic ‘User defined function is not working!’ is closed to new replies.
