May 5, 2022 at 9:38 am
kschoenborn
SubscriberHi there, A User is searching for user defined Hotkeys in the 2020R1 Release of discovery. He would e.g. like to use the S key for Split Body like in SpaceClaim or the F9 key for Hide Body. I searched the Online Help but I could not find any
May 5, 2022 at 10:01 am
Subashni Ravichandran
Forum ModeratorHello Klaus
Let me check if there is any document with the Hotkeys.
Some of the Hotkeys from SpaceClaim, such as P for Pull and X for cross section work in Discovery too,
May 5, 2022 at 12:21 pm
kschoenborn
SubscriberHello Subashni,
Thanks for the quick answer. The User is well aware of all the existirng Hotkeys. He would like to define his own Hotkeys. -
May 9, 2022 at 7:37 am
I checked with my team and I understand that User-defined Shortcuts are not available in Discovery now.
Although, all SpaceClaim shortcuts work with Discovery.
Please check below documentation link for SpaceClaim shortcuts.
Keyboard shortcuts (ansys.com) -
May 9, 2022 at 7:56 am
kschoenborn
SubscriberReply from Klaus
Hello Subashni
That is my understanding, too. User-defined Shortcuts are currently not available in Discovery. The User ist well aware of the Shortcuts that are available in SpaceClaim. However, he wants to define his own Shortcuts to make the GUI behave in a similar way as the Workbench GUI, e.g. F9 for "hide body". I understand that this is an enhancement request to the GUI. Would you be placing this user request? The user is Mr. Bernhard Gumpetsberger from the Company Bilfinger Industiral in Wels, Germany. -
May 9, 2022 at 8:17 am
Forum ModeratorThanks for the customer information Klaus
I will make sure to update the enhancement request. -
May 9, 2022 at 9:29 am
kschoenborn
thanks !
kind regards, Klaus
- The topic ‘User Defined Hotkeys’ is closed to new replies.
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3151
1680
1470
