Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
User Defined Model (UDM) can not simulate in HFSS 18
    • Leo_UCDavis
      I was redirected from the old support portal. Posting the same question here. The original SR# is 1794782461.
      Update:
      • This seems to be an issue with the 18 version. The original OnDieSprialInductor UDM runs well in HFSS 15, but not in 18.
      Hi
      I was trying the OnDieSpiralInductor  UDM that shipped with HFSS. I can add the model and change its parameters with no problem. However, when I try to simulate the setup, I get the following error.
        HFSSDesign1 (DrivenModal)
          [error] Objects "ILD" and "Inductor" intersect. (2:584 PM  Aug 13, 2018)
      Obviously this is due to the ILD and Inductor intersecting each other. This seems to be a problem with UDM script. For the sake of demonstrating the simulation problem, I removed the creation of the ILD from the UDM script and saved it as a new UDM with the name "Inductor".
      After setting up everything correctly and passing the green "Validate" check, HFSS gives the following messages before halting the simulation.
      *Global - Messages
        [info] Window "Project4 - HFSSDesign2 - Modeler" has been closed to avoid display Instability  Please reopen
      Project4 (DScratch/Ansys/)
        HFSSDesign2 (DrivenModal)
          [error] Failed to refresh submodel Inductor1 (3:21:59 PM  Aug 13, 2018)
          [error] Body could not be created for part Port1 because of invalid parameters of this part or some of its parent part/coordinate system. (3:21:59 PM  Aug 13, 2018)
          [error] Body could not be created for part Port2 because of invalid parameters of this part or some of its parent part/coordinate system. (3:21:59 PM  Aug 13, 2018)
          [error] Body could not be created for part Inductor because of invalid parameters of this part or some of its parent part/coordinate system. (3:21:59 PM  Aug 13, 2018)
          [error] Body could not be created for part Via1 because of invalid parameters of this part or some of its parent part/coordinate system. (3:21:59 PM  Aug 13, 2018)
          [error] Body could not be created for part Via2 because of invalid parameters of this part or some of its parent part/coordinate system. (3:21:59 PM  Aug 13, 2018)
          [error] Body could not be created for part Underpass because of invalid parameters of this part or some of its parent part/coordinate system. (3:21:59 PM  Aug 13, 2018)
          [error] Body could not be created for part Inductorfeed1 because of invalid parameters of this part or some of its parent part/coordinate system. (3:21:59 PM  Aug 13, 2018)
          [error] Body could not be created for part Inductorfeed2 because of invalid parameters of this part or some of its parent part/coordinate system. (3:21:59 PM  Aug 13, 2018)
          [error] Port '1': Both endpoints of port lines must lie on the port. (3:21:59 PM  Aug 13, 2018)
          [error] Port '1': Length of port lines must be greater than zero. (3:21:59 PM  Aug 13, 2018)
          [error] Port '2': Both endpoints of port lines must lie on the port. (3:22:00 PM  Aug 13, 2018)
          [error] Port '2': Length of port lines must be greater than zero. (3:22:00 PM  Aug 13, 2018)
          [error] Simulation completed with execution error on server: Local Machine. (3:22:00 PM  Aug 13, 2018)
    • Leo_UCDavis
      bump
