TAGGED: rm-xprt, rmexpert, rmxpert, rotating-machinery, StepMCore
April 22, 2022 at 3:02 pm
Magnet_man
SubscriberI am trying to use the RMxprt to make a simple stepper motor, but when i change the "InfoCore" property to 3 to select magnets, i get an error that "User Defined Primitive : RingLength must be larger than 0."
I simply cannot figure out how to edit this RingLength parameter, as i have no idea where it's located..
I am using ansys electronics desktop 2020 R1, and i'm using the version 19.4 of the StepMCore, updated 01-01-2019.
Hope anyone can help!
May 2, 2022 at 8:46 amMay 2, 2022 at 8:57 amViewing 2 reply threads- The topic ‘User defined Primitve error for RMxprt when using StepMCore: RingLength must be larger than 0.’ is closed to new replies.
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Concept of Interpolation Sweep in HFSS
- Error
8808
4658
3151
1680
1470
