March 1, 2022 at 1:27 pm
ncoonan
SubscriberI'm reviewing a model where the user has used several user defined result expressions for stress plots.
Examples are Ttop2, Tbottom2, FTop5, Fbottom5, etc.
I'm not seeing these options under the solution worksheet. Where can i find an full listing of these expressions?
Thanks!!
March 1, 2022 at 1:44 pmRohith Patchigolla
Could you please share a snapshot of one of this User defined result?
These examples are not native expressions for User defined results (such as UX, USUM, SX etc).
I believe, the user created Identifiers (for some results upstream) - one can assign a custom string as an identifier for any result object (in the details box) and one can then directly use these identifiers (custom strings) in a new User defined result.
Hope this helps.
Best regards Rohith
March 1, 2022 at 4:43 pmncoonan
SubscriberThanks for your response.
That's exactly what it was, an identifier was applied to standard the standard stress plots, then maximum's determined.
Thanks again.
2706
2146
1357
1144
462
