TAGGED: acceleration, fluent, sloshing, transient, udf
June 29, 2023 at 11:55 am
Bernardo Nunes
SubscriberHey everyone
I am trying to do a sloshing simulation inside a reservoir using accelaration data points on specified instants. I´m a little lost on how to insert these data points as the boundry conditions. For a more simple simulation i used the equations as named expressions for the X, Y and Z accelarations but now i want to know how to insert something like a CSV file as the named expression. I think a possible way to do this is by creating a user defined function that folows the datapoints but i dont understand how we can insert it as a acelaration boundy condition.
Help on this matter would be very apreciated
June 30, 2023 at 1:55 pm
Supreetha J
SubscriberHello,
You can use Profiles for this. For more information, kindly refer to the profiles section in the User's Guide 7.9. Profiles (ansys.com)
If you are not able to access the link, please refer to this forum discussion: Using Help with links (ansys.com)I hope this helps.
Thank you.
June 30, 2023 at 4:07 pm
Bernardo Nunes
SubscriberThank you for the help! In theory should work perfectly, but im having trouble uploading the csv file to fluent. Its stuck in the "reading profile please wait" message and after i try to stop the reading the program freezes. Im using a csv according to the file rules in profiles and i tried using a file with only 6 or 7 points. Nothing seems to work
7714
4484
2957
1437
1322
