August 7, 2019 at 2:06 am
kfouladi
SubscriberHello,
I was wondering if anyone could help me with using a UDF with system coupling (co-simulation). I have two issues with this UDF
(1) It write the output twice for each time step with the first time the value is zero.
Also, when the run is completed, I get the following messages and error.
(DP 0) system coupling run completed successfully
(DP 0) failed in handling fluent - this error is repeated a number of times
(DP 0) A solver failure occurred during the run in the Fluid Flow (Fluent) system
Update failed for the Solution component in System Coupling. The coupled update for system Fluid Flow (Fluent) threw an exception. It was not possible to unlock the associated editor.
Here is the output:
time=0.000000, Volume integral ff= 0
time=0.000000, Volume integral ff= 8.8676e-08
time=0.001000, Volume integral ff= 0
time=0.001000, Volume integral ff= 8.26847e-08
time=0.002000, Volume integral ff= 0
time=0.002000, Volume integral ff= 8.22356e-08
time=0.003000, Volume integral ff= 0
time=0.003000, Volume integral ff= 8.28172e-08
August 9, 2019 at 12:43 pm
Ansys EmployeeIf you're just reporting a value can you use a monitor and report?
August 9, 2019 at 3:44 pm
kfouladi
SubscriberNo, I am actually calculating a value, like energy dissipated throughout the domain. The UDF that I put out is a brief version of that UDF to show what kind of problem I am facing.
August 13, 2019 at 9:50 am
Ansys EmployeeAnd if you don't use the UDF? Trying to narrow down the cause.
August 14, 2019 at 11:26 am
kfouladi
SubscriberI don't have these errors if I don't use UDF.
August 14, 2019 at 2:04 pm
Ansys EmployeeOK, so it's the UDF. If you go through the UDF where does it interact with the Fluent solver? Turn the interactions on one at a time until it fails: that is probably the cause of your problem.
2600
2088
1319
1108
459
