Using a visco-hyperelastic material in explicit analysis
    • Junan
      I am facing issues try to use a visco-hyperelastic material in explicit dynamics. Can anyone assist me with this?
      When I use static structural, I am able to successfully develop a visco-hyperelatic material using the "prony shear relaxation" under the viscoelastic tab. However when I switch to explicit dynamics, the "prony shear relaxation" tab is lost. I can only include viscoelastic behavior by going to linear elastic tab.  And this doesnt work.
    • Missy Ji
      Prony series is not support by ANSYS explicit dynamics, if you need to use that, you can consider using LS-Dyna.
      Generally Explicit dynamics is used to simulate things happened in a very short period of time, for example, milllsecond level, which is different from the time scale for prony series to help.
    • Junan
      Mji, Thanks for your response.
