January 18, 2023 at 4:13 pm
martinmi
SubscriberHallo all, i ihave a problem when i try to use the addplanarsolid() function in python. I first create vtx and an cell array a like:
vtx = np.array([[0,0,0], [1e-6,0,0], [1e-6,1e-6,0], [0,1e-6,0], [0,0,1e-6], [1e-6,0,1e-6], [1e-6,1e-6,1e-6], [0,1e-6,1e-6]])
a = np.array([[1,4,3,2], [1,2,6,5], [2,3,7,6], [3,4,8,7], [1,5,8,4], [5,6,7,8]])
addplanarsolid()
set('vertices',vtx)
set('facets',a)The result that i am getting is:
I saw that some other users have the same problem, so if any Admin know how to resolve the problem,
please post an example code.
I tested the same structure with ,lsf script and it was working perfectly. The Problem is when i try to add addplanarsolid with Python.
Best regards,
Martin
January 25, 2023 at 5:40 pm
Taylor Robertson
Ansys EmployeeHello Martin,
It seems to me that the list of facets would be problem. This should be a list of np.arrays, with each entry correnponding to a single facet. Not an NP array of the facets.
https://optics.ansys.com/hc/en-us/articles/360034901573-Planar-solid-Simulation-Object
The following are methods of a session handle, so they should be used like fdtd.addplanersolid(),
addplanarsolid()
set('vertices',vtx)
set('facets',a)I would suggest using putv and compare vtx and a between the API and lsf methods. However if you have a method that works in lsf pehaps you can just use fdtd.eval('' lsf script'')
https://optics.ansys.com/hc/en-us/articles/360041401434
Best Regards,-
January 26, 2023 at 4:22 pm
martinmi
SubscriberHi Taylor,
Thanks for the reply! After many tries I just found the right data type for the facets. So if someone creates a planarsolid object with Python, the vertices and facets should be defined as follows:
- vtx = np.array([[0,0,0], [1e-6,0,0], [1e-6,1e-6,0], [0,1e-6,0], [0,0,1e-6], [1e-6,0,1e-6], [1e-6,1e-6,1e-6], [0,1e-6,1e-6]])
- a = [[np.array([[1,4,3,2]], dtype = object)], [np.array([[1,5,8,4]], dtype = object)], [np.array([[1,2,6,5]], dtype = object)], [np.array([[2,6,7,3]], dtype = object)], [np.array([[3,4,8,7]], dtype = object)], [np.array([[5,6,7,8]], dtype = object)]]
After that, as you have already mentioned, you need(can) pass the facets and vertices to Lumerical Workspace:
lum.putv('vertices',vtx)
lum.putv('facets',a)And then use lum.addplanarsolid(vtx,a),
I have run into another problem, this time I think it is more of a problem with the Lumerical Visualization option. So after I create the structure I want, for example a taper, I can't see one of the sides of the taper. Then when I rotate the object in Lumerical, some of the sides of the taper disappear in a certain position and then come back after I rotate the object back. Do you know if this is a problem that could affect my simulation results or is it more of a Lumerical Visualization problem? I have attached some photos that I took while rotating my taper. All the pictures are from the same object, but taken from a different object rotation angle.
Best Regards,
Martin
- Error on Lumerical device
2726
2156
1359
1150
462
