March 22, 2021 at 4:25 pm
soloviev
SubscriberHello,
I am trying to create a report for momentum at a surface in my model. I created report definitions for mass and velocity and am now trying to use the monitor expression to do mass*velocity for momentum.
When I do this I get the error that the expression is not single valued.
Thanks,
Alex
March 22, 2021 at 4:29 pmYasserSelima
SubscriberThis expression calculates the values at all cells. To have it on a surface ... select reduction ... average ... nMarch 22, 2021 at 4:49 pmMarch 22, 2021 at 5:16 pmYasserSelima
SubscriberAverage(your_expression, ['surface_name'],Weight='Mass')nMarch 22, 2021 at 6:14 pmsoloviev
SubscriberThank you! I see why my location is invalid. It is a plane I created at a specified height. Is this possible or do I have to use a location at a boundary?nMarch 22, 2021 at 6:26 pmYasserSelima
SubscriberI never did this before, so I don't know. But if your location is not available when you select the location button, probably it is not possible.nBut you can still do it with the report definition. Define a custom field function ... (mass*velocity) and get its mass average on your surface through report definitionnMarch 22, 2021 at 6:31 pmsoloviev
SubscriberThank you! I didn't know I could create custom field variables.nMarch 22, 2021 at 6:54 pmYasserSelima
SubscriberYou are welcome!nViewing 7 reply threads- You must be logged in to reply to this topic.
2706
2142
1355
1144
462
