November 9, 2023 at 10:48 am
hwmachine
Subscriber -
November 9, 2023 at 11:18 am
hwmachine
SubscriberHi everyone.
I am doing harmonic response analysis by ANSYS APDL to evaluate the variation of the natural frequency of the rotating structure causing by the unbalanced excitation.
First I build a simple equal-radius cylindrical shaft using BEAM188. Second I give it a constant force on one end side. Then, I make it rotate in the axial direction with using CMOMEGA, also the Coriolis effect is activated. Finally, the SYNCRO is set up as the unbalanced excitation. The screenshots are shown below.
However, during the postprocssing, I found the peak value variation of amplitude-frequency response curve is not what I supposed, for example, when the ratio in SYNCRO is 3, then the frequency of the peak value should be twice of the frequency when I change the ratio in SYNCRO to 2, which can be considered as the resonance of the rotating structure is advanced because of the ratio of unbalaced excitation is increased: 3-1=2*(2-1). The screeenshot below shows how the frequency changed when the ratio = 2, 3, 4. X-axis is the frequency in HARFRQ (0-10000Hz), y-axis is the displacement amplitude.
Can someone please tell me if I made some mistakes in doing unbalance harmonic response analysis, or maybe what I supposed is wrong: the variation of natural frequency is not proportional to the ratio in SYNCRO?
Many thanks!!! -
November 13, 2023 at 1:01 pm
Ashish Khemka
Forum ModeratorHi,
Please see if the following link helps you:
Chapter 7: Rotordynamic Analysis Examples (ansys.com)
How to access the ANSYS Online Help
Ashish Khemka
- Licensing – Request name does not exist in the licensing pool
- 2022 R1 Ansys Mechanical APDL: QXcbConnection: Failed to initialize XRandr
- error “ansyslmd: Cannot connect to license server system. (-15,10032)
- The analysis systems in Workbench are missing
- Student license renewal
- Mechanical APDL Launcher Options
- how to open files created from newer version by using the older version of ansys
- Problems using 2022/R2
- Ansys Helic Tools Installation Issue: Missing Helic_PDK directory
- Results Probe in ANSYS Workbench
8808
4658
3153
1688
1474
