May 5, 2022 at 12:24 pm
nick5990
SubscriberHi, I've been using CES Edupack 2020 as part of University course to aid with materials selection
Using the Level 2 database, with "Price GBP / Kg " on Y axis vs "Recycle fraction in current supply %" on X axis, I obtained the below chart, and noticed the PET is above 20% for around £1 / kg.
May 5, 2022 at 2:08 pmj_p
Ansys EmployeeHello nick5990
Thank you for your question and pointing this out. We don see this in the latest version of EduPack (2022R1), as you can see in the image attached. As shown, the value for the recycle fraction ranges between 17.3-19.1% for PET at Level 2. Thus, I would kindly invite to to upgrade to the most recent release.
Just for your understanding: Level 3 databases are updated regularly to match industry changes, while Level 1/2 databases are only updated yearly to allow courses to teach with the same data over a whole academic year - so there can sometimes be discrepancies between data in L2 and L3 as a result.
I hope this helps.
Best János
May 5, 2022 at 4:15 pmnick5990
SubscriberHi Janos, I wasn't pointing out a discrepancy (the differences just appear to be due to detail in L2 and L3 databases in my opinion.
It is not possible for me to update CES 2020 to a more recent version as its not been made available for the module I'm studying. Hence please refer to CES Edupak 2020 for this thread.
Please see my previous post re amorphous/ crystalline question which may have been overlooked
May 5, 2022 at 7:23 pmj_p
Ansys EmployeeHi nick5990,
If you would like to include semi-crystalline PET, than you must include the optical properties 'translucent' in your limit stage. This means the material transmits little diffuse light (see science note for more details) and may - depending on the application - also be considered for 'optical' (partially light-resistant) purposes. There are of course specific manufacturing steps that can be taken to make semi-crystalline PET more transparent, but they are not considered here.
You have of course also the option to limit your results by pre-selecting the material family you are looking for, i.e. thermoplastic amorphous or semi-crystalline, but only the former PET variant is considered 'optical quality'.
I hope this answers the question. If not may I kindly ask you to elaborate. Thanks!
May 5, 2022 at 7:54 pmnick5990
SubscriberHi j_p, thanks for info re "translucent" - I didn't think to check the definition, and that's valuable what you posted. I'm only interested in "transparent" and "optical".
Re amorphous plastics such as amorphous PET and amorphous PMMA - are these considered solid?
Viewing 4 reply threads- The topic ‘Using CES edupak to find optical plastics & question re amorphous / semi-crystalline / crystalline’ is closed to new replies.
Trending discussions- Adding New Material
- Exothermal reaction kinetics
- Fatigue SN curve
- Curve Fitting – “Error Norm to Fit” expression
- material designer
- Ansys Granta Selector license problem
- Anyone experience in how to model a glass filled polyamide (Nylon)
- Strain Life Parameter
- Multistack layer model
- adding new material in Granta
8808
4658
3155
1688
1478
