TAGGED: ansys-maxwell, maxwell, system-coupling, transient-analysis
November 22, 2021 at 9:45 am
MohamedNabil
SubscriberDear,
I would like to use different matlab optimization algorithms like particle swarm etc.
I'm trying to implement it inside Maxwell optimization instead of the default matlab fmincon function but i have some issues. For example, [x,fval,exitflag,output] = particleswarm (wrapperfunc, [6], $ANS_MINVAL, $ANS_MAXVAL, options).
I need to better specify options and number of variables.
I would like to implement my own optimization algorithm in matlab and use it inside Maxwell.
Could someone please help me with some documentations and examples?
Thanks
BR,
Mohamed
November 22, 2021 at 3:18 pmNavya C
Ansys EmployeeHi @MohamedNabil For your requirement on "how to implement your own optimization algorithm in MATLAB", I suggest you reach out to MATLAB support.
And for how to use the MATLAB optimization with Maxwell, you can refer to the Maxwell help and there is extensive information detailed.
Ansys employees may not be able to help with the core scripting on an open forum like this. But I encourage others in the forum to pitch in.
Regards Navya
November 22, 2021 at 3:21 pmMohamedNabil
SubscriberThanks @ nchode for your comment.
I maybe was short in "how to implement your own optimization algorithm in MATLAB" but i mean to couple it with maxwell. so i made an optimization algorithm in matlab and i want to connect it with. Maxwell.
November 22, 2021 at 3:27 pmNavya C
Ansys Employee@MohamedNabil Can you check the above-mentioned Maxwell help section for linking Maxwell with MATLAB?
If you could not find or face any issues please let us know. We will surely help you with that.
Regards Navya
November 23, 2021 at 8:18 amMohamedNabil
Subscriberthanks for your help.
Indeed, I'm aware of this part. But i cannot find how to specify correctly the number of variables [6] and options.
Besides, this is a ready to use matlab optimizer.
But I have a custom made optimizer in matlab and i need to call this optimizer which is not ready function in matlab.
This optimizer should receive the computed objectives from Maxwell and send change to the design parameters in Maxwell.
BR Mohamed
April 23, 2022 at 8:40 amSupriya
SubscriberHello sir,
Do you solve your problem?
April 26, 2022 at 8:35 amMohamedNabil
SubscriberNo, i gave up because there is no clear help. If you solve it then let me know.
Best regards Mohamed
Viewing 6 reply threads- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Concept of Interpolation Sweep in HFSS
- Error
8754
4658
3151
1678
1454
