Using Discovery AIM, getting results in Flow simulations stuck at 19%
    • Bellwar
      I have a trouble getting results from AIM after getting the flow simulation done. Everything is working smoothly until I open results where I can see the velocity. Afterwards I try to add result and pressing evaluate the program freezes at 19% not responding, saying Evaluation starting.... In task bar the computer is saying Python is using 30% of my CPU. I do have only 8 Gb of RAM it just the aim is not eating all of it and the Flow simulation which should be much harder to do is all fine. It is the results after that get me stuck. The object is simple sphere and simulation of air flow around it.n
    • Naresh Patre
      Hello Bellwar nDid you try reopening the project and evaluate the result? Which result are you trying to evaluate? Can you try with another result type and check if you are seeing the same issue?n
