October 22, 2018 at 4:17 pm
durgaprasadram
SubscriberHi guys,
I want to know how to use the command "Fill_Face_Part_With_Same" in parallel udf. Usage of the line my udf brings out error as undefined identifier.
Thanks
Mohan
October 22, 2018 at 4:54 pm
Karthik R
AdministratorHello,
Could you please provide a little more details about your UDF? Perhaps, attach a screenshot of the same? What is the purpose of your UDF?
Thank you.
Best Regards,
Karthik
October 22, 2018 at 6:01 pm
durgaprasadram
SubscriberHi Karthik,
I am trying to implement a multi-phase algorithm, which is still in its development stages. In parallel environment, I would be using information from neighboring cells, (through node, face and cell loops). As a precaution, i need to ensure that the id on the partition face (connecting the external cell) has the same value as compute node. From, Ansys manual, i understand that explicit way of doing it is by using Fill_Face_Part_With_Same. The document however lacks clarity in its usage. I know that for most variables its usage is not required (as per the fluent user document). The question pertains to the syntax and in my understanding, is not influenced by the underlying algorithm.
Also, i there any way i can access the information of multi-phase interface normal vector in fluent (VOF)?
Thanks for your help
Mohan
2524
2064
1279
1096
456
