November 15, 2018 at 2:38 pm
Vanderbezi
SubscriberGreetings,
i am using the following APDL commands to measure the rotation of two external points:
*get,my_rotx1,node,my_pilot1,rot,x
*get,my_rotx2,node,my_pilot2,rot,x
pi=acos(-1)
my_rotx1=my_rotx1*180/pi
my_rotx2=my_rotx2*180/pi
I am using 10 loadsteps in a static analysis and getting only the results for the last .
How can i get these results for the different loadsteps?
regards,
Vanderbezi
November 15, 2018 at 3:32 pm
jpasquerell
Ansys EmployeeIn post1 the set command tells the program what results to read from the rst file.
set,first
*do,jj,1,10
! put your block of commands here
*if,jj,lt,10,then
set,next
*endif
*enddo
November 16, 2018 at 2:13 pm
November 23, 2018 at 1:26 pm
Rohith Patchigolla
Ansys EmployeeHello Vanderbezi,
Could you paste your APDL commands used instead of snapshot? The picture is not so clear.
But from my understanding, you simply pasted your command set (in your first post) at the location Jim suggested in his script.
If yes, the values for parameters, my_rotx1 (for example) will be replaced during each loop by values at the next result set and the values you finally get are those corresponding to last result set.
Do you need all the 40 parameters in the details of the command snippet?
If not, you can simply modify the script as shown below, by adding %i% to the name (and removing my_), and after the loop, just getting those values needed into the details box of the command snippet.
set,first
*do,jj,1,10
*get,rotx1,node,my_pilot1,rot,x
*get,rotx2,node,my_pilot2,rot,x
pi=acos(-1)
rotx1_set_%i%=my_rotx1*180/pi
rotx2_set_%i%=my_rotx2*180/pi
*if,jj,lt,10,then
set,next
*endif
*enddo
!Extracting rotx1 at set 5
my_rotx1 = rotx1_set_5
Other option is to use an array instead of a scalar parameter in the loop and write out the array data to an external file using *CFOPEN and *VWRITE commands for example.
Hope this helps.
Best regards,
Rohith
2066
1279
1096
457
