August 30, 2023 at 2:13 pm
Aneela Banda
SubscriberWe have current license server is live on a network that is not accessible by our HPC cluster. Can we know how we can get a file based license from the existing licensing and use it on our HPC cluster which has Ansys Fluent 2021R1 configured and we are using RHEL 8.5 . Can we also know if we can use 2020 's version of ansys fluent license server for 2021 R1 on HPC?
August 31, 2023 at 7:26 pm
George Karnos
Ansys EmployeeI do not believe this is a licensing issue, however if you want to switch where your license exists, You can have your License Administrator or Ansys Support Coordinator rehost the license key to another machine. You can also reach out to your ANSYS Account Manager.
The Error in the pic you posted look to be prerequiites missing or incompatible:
You can also search the form forĀEVP_KDF_ctrl
Other ideas may be listed.
See Post: https://forum.ansys.com/forums/topic/ansys-installation-on-centos-8-0/
Have you confirmed all prerequisites have been installed?
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/installation/unix_sysprereqs.html
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/installation/unix_addlhwswreqt.html
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/installation/unix_thirdparty.html
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/installation/unix_platformdetails.html
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/installation/unix_platform_libraries.html
Computational Fluid Dynamics (CFD) helps engineers design products in which the flow of fluid components is a significant challenge. These different use cases often require large complex models to solve on a traditional workstation. Click here to join this event to learn how to leverage Ansys Fluids on the cloud, thanks to Ansys Gateway powered by AWS.Ā
Earth Rescue ā An Ansys Online Series
- License Error
- Workbench not opening
- Workbench error
- how to open DesignModeler
- FlexNet Licensing – Not running
7742
4502
2961
1449
1322
Ā© 2023 Copyright ANSYS, Inc. All rights reserved.
