Using MPCHG command with engineering data materials
    • helen.durand
      Hello!nI have two materials defined in 'engineering data' of a 'transient thermal' simulation. Initially, the entire geometry is assigned to one material using the UI.nI want to be able to use the MPCHG command to change the material assignment of some elements in my simulation during the simulation (by using a command object), but I do not know what material number is associated with each material I assigned in 'engineering data.' nHow to I find (or assign) a material number for each material in 'engineering data'?nThank you!n
    • Ashish Khemka
      Hi Array,nnPlease refer to the discussions below where user have same query on using the MPCHG command:nnArraynArraynRegards,nAshish Khemkan
