January 27, 2022 at 5:27 am
yisu0279
SubscriberCurrently, I am using the following command: "C:Program FilesMicrosoft MPIBinmpiexec.exe" -n 24 "C:Program FilesLumericalv212infdtd-engine-msmpi.exe" -t 1” “file path”, but it can only run one .fsp file at one time. I want to add more .fsp at the same time. What should I add in the command line?
January 27, 2022 at 7:22 pmLito Yap
Ansys EmployeeJanuary 28, 2022 at 8:29 pmyisu0279
SubscriberCould I also specify the number of processors and the number of threads? In the discussion, it only says how to specify the number of processors, but the number of threads is always 1 by default.
January 28, 2022 at 8:38 pmLito Yap
Ansys Employee<
When running with MPI you only need to specify the processes - which runs each MPI process on 1 thread or logical core on your machine. So -n 6 will run on 6 logical cores/threads on your machine.
February 3, 2022 at 5:47 amyisu0279
SubscriberCould I simulate my fsp file associate with my script file on the terminal?
February 3, 2022 at 8:25 pmLito Yap
Ansys EmployeeRunning scripts will require the CAD/GUI and a GUI license.
On Linux/terminal, running script.lsf files will require a graphical/GUI access like VNC or Xforwarding. Then run the script.lsf from the CAD/GUI. Otherwise, you can run from the terminal with a graphical/GUI connection as:
/opt/lumerical/v221/bin/fdtd-solutions -nw -trust-script -run
Otherwise, without a GUI/graphical connection, you can only run the simulation(.fsp) files from terminal.
Viewing 5 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
3778
2579
1825
1242
598
