Using Multiple Nodes in Fluent
    • krany3
      I'm trying to use maximum cores on 2 nodes in fluent. Can anyone explain how can I utilize both the nodes' cores for parallel processing in fluent?
    • Karthik R
      Administrator
      On what operating system are you running fluent on? Can you elaborate a little as to how you are currently running Fluent? Also, how many cores do you have on each node.
      Depending on the operating system, you can launch Fluent either using command line or through remote solve manager. You can find more details about the exact commands on the Fluent Users Guide (chapter 34). You should be able to find the exact commands (depending on your operating system). I hope this helps.
      Best Regards,
      Karthik
    • krany3
      Thanks
    • DrAmine
      Is your problem now solved?
    • krany3
      Mostly solved. Thanks for asking
Viewing 4 reply threads
